Scheduled posts not working (Docker issue?)
I am hosting Ghost in a Docker container on my own host and scheduled posts do not seem to work.
Error
ghost-1-ghost-1  | [2025-01-03 21:26:57] ERROR The server has encountered an error.
ghost-1-ghost-1  |
ghost-1-ghost-1  | The server has encountered an error.
ghost-1-ghost-1  |
ghost-1-ghost-1  | Error ID:
ghost-1-ghost-1  |     7614c300-ca19-11ef-a33a-77a5ae058a1e
ghost-1-ghost-1  |
ghost-1-ghost-1  | Error Code:
ghost-1-ghost-1  |     ETIMEDOUT
ghost-1-ghost-1  |
ghost-1-ghost-1  | ----------------------------------------
ghost-1-ghost-1  |
ghost-1-ghost-1  | RequestError: Timeout awaiting 'request' for 5000ms
ghost-1-ghost-1  |     at /var/lib/ghost/versions/5.105.0/core/server/adapters/scheduling/scheduling-default.js:319:23
ghost-1-ghost-1  |     at ClientRequest.<anonymous> (file:///var/lib/ghost/versions/5.105.0/node_modules/@tryghost/request/node_modules/got/dist/source/core/index.js:792:61)
ghost-1-ghost-1  |     at Object.onceWrapper (node:events:632:26)
ghost-1-ghost-1  |     at ClientRequest.emit (node:events:529:35)
ghost-1-ghost-1  |     at TLSSocket.socketErrorListener (node:_http_client:501:9)
ghost-1-ghost-1  |     at TLSSocket.emit (node:events:517:28)
ghost-1-ghost-1  |     at emitErrorNT (node:internal/streams/destroy:151:8)
ghost-1-ghost-1  |     at emitErrorCloseNT (node:internal/streams/destroy:116:3)
ghost-1-ghost-1  |     at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
ghost-1-ghost-1  |     at Timeout.timeoutHandler [as _onTimeout] (file:///var/lib/ghost/versions/5.105.0/node_modules/@tryghost/request/node_modules/got/dist/source/core/timed-out.js:42:25)
ghost-1-ghost-1  |     at listOnTimeout (node:internal/timers:571:11)
ghost-1-ghost-1  |     at process.processTimers (node:internal/timers:512:7)
  1. I have checked that the container is able to ping the hostname (phlog.thesatelliteoflove.com)
  2. I have checked that i can use curl from inside the container and that it can successfully return the site using the configured URL (https://phlog.thesatelliteoflove.com)
  3. A curl from inside the container to curl -X PUT https://phlog.thesatelliteoflove.com/ghost/api/v0.1/schedules/posts/6778405b3755e70001cfd2bf returns the following error:
{"errors":[{"message":"Resource not found","context":null,"type":"NotFoundError","details":null,"property":null,"help":null,"code":null,"id":"88610750-ca1c-11ef-82ad-6531cade3680","ghostErrorCode":null}]}
Docker Compose:
services:
  ghost:
    image: ghost:5-alpine
    restart: unless-stopped
    environment:
      - database__client=sqlite3
      - database__connection__filename=/var/lib/ghost/content/data/ghost.db
      - database__useNullAsDefault=true
      - url=https://phlog.thesatelliteoflove.com
    volumes:
      - ghost:/var/lib/ghost/content
    extra_hosts:
      - 'phlog.thesatelliteoflove.com:172.20.0.5'
volumes:
  ghost:
    driver: local
networks:
  default:
    external: true
Caddyfile
phlog.thesatelliteoflove.com {
    reverse_proxy ghost-1-ghost-1:2368
Hi there,
I spend quite some time with this error. :grinning: Not sure if it is also a fix for you, but…
For me it was enough to add (or create the file if its not there) :
in /etc/docker/daemon.json
  "dns": ["8.8.8.8", "1.1.1.1"]
and restart Docker Service ( systemctl restart docker ).
