Server Control/Monitoring Panel
Hello all.
I’ve been using Ghost on CloudPanel for a good while, because I like the server control and monitoring it offers.
With the announcement that the ghost-cli will be deprecated next year, I have decided to migrate to the Ghost Docker Compose Setup.
However, I would like to have a server panel for monitoring at least. So I’d like some advice, suggestions, etc.
Currently, I’m using Cockpit, but it of course, has issues, ‘bugs’, needs additional tweaks to work properly with Ubuntu, etc. I have tried to use aaPanel with Ghost on docker, but it has issues as well, and I don’t need everything else that comes with it.
So, does anyone have any suggestions on a server monitoring control panel that I can use alongside of my docker and Ghost install?
Thank you in advance
What do you want to monitor? Folks here usually use Tinybird, but I like Bezel or Grafana; they provide an entry-level and a full overview, respectively.
Thank you.
I basically want to monitor the server itself: CPU, RAM, Processes, updates, etc.
I’m currently using agent 360 and Pinguzo. Would like to have it hosted on my server, so I’m gonna check out Beszel
Nice, it is a very nice app. If you want something reliable and ultra (more) lightweight you can also try Uptime Kuma:
I’m using dokploy. The experience has been good. I made a few adjustments to Compose so it would work properly, but without TinyBird.
