Is it possible not to have the post title as part of the URL for the post, but instead have a shortened dedicated code for each post in its URL; leaving the domain still showing?
I frequently use longish post titles causing it to be more informative, meaningful and elegant when opening the post, but they do look rediculous in the web browser’s URL.
If you open the post settings menu (right side, the same place you’d apply a tag), you can set the post slug to anything you’d like. While ghost generates the slug from the title if you haven’t chosen something different, you can change it!
Having said that, for Seo purposes, you may want a shorter version of your title instead of a random code. :)
Of course. Silly me. Thanks. RR
