I would like to add the sign-up form for Ghost to the bottom of some Medium articles. However, I don’t see a way to do that. (I just get the code added to the article.) Am I missing something, or does Medium not allow scripts?
It’s been a long time to use Medium, but as far as I know, Medium doesn’t support embedding HTML code. You can consider putting a direct subscribe link (https://yourdomain.com/#/portal/signup)
In going back through some saved web pages, I found the solution: Medium does display Google forms.
