Hi there, I’m using Spotlight theme in Ghost - DIScover Conference Goodies - everything is updated and I’m using the latest version of the theme as far as I can tell and Ghost was updated to the latest version today. For some reason, when I insert the Signup card, it shows fine in draft mode but when I publish, it disappears. Can you confirm that the Signup card feature is still active? I’ve already gone to Labs to toggle on the beta enhanced editor role setting…
I’m using Chrome - it also does not appear to work in Safari.
1 - make sure you aren’t logged in - it doesn’t display for members who are signed in, since there’s no reason to ask them to subscribe if they already are
2- check your browser console for any error message (F12 and then browser tab)
OF COURSE! duh
Thank you so much - it works now!
That’s unusual — the signup card should still work on the Spotlight theme. If it shows in draft but disappears once published, it might be a theme compatibility issue rather than Ghost itself. Have you tried switching temporarily to another default theme (like Casper) just to see if the card renders correctly there? That would help confirm if the issue is theme-related.
