I’m using Ghost on $5 Digital Ocean droplet - mrhack.io
It has few thousands posts, around 10K monthly visits.
I recently migrated from WordPress. But, sometimes the website is not loading. Seems it is due to high CPU usage.
Some help from DO support:
The most common reason of this issue would be MySQL stopped running. It stopped or failed to start as a result of not enough memory. Restarting the server is only a temporary fix and will not solve the problem.
Any advice? I know maybe I need to upgrade to a bigger droplet, but maybe other solutions?
