Snippets Saved Not Displaying
Fill out the following bug report template with as much detail as possible!
Are you sure this is a bug? If you just need help, post in the developer help category. If it’s a feature request, head to the ideas category.
Issue Summary
  • Snippets will not save if you use certain letters of the Alphabet as the first letter in the Snippet name you save it under. A -T works fine, but S-Z once saved will not show up in your saved Snippets.
  • What did you expect to happen?
    Any snippet saved to show up in your saved snippets regardless what you label the snippet.
Steps to Reproduce
  1. Go create a snippet while editing a page (not a post, problem may persist there as well, but did not check.
  2. Save snippet with with any name that starts with U, V, W, X, Y , or Z. Examples: Yellow Snippet, X-Ray Data, Unicorn Photo, Whiskey menu, Zebra Cakes. Because those words start with the letters mentioned above…
  3. Now when you search for the saved snippet, it will not be shown in your list of saved snippets.
Windows 10, Brave Browser,
**Ghost Pro User on newest version, using the taste theme.
These are all the details I can provide, as I am not a tech person.
