Stripe Integration Failing
Hi
Im running ghost v3. Ive setup Stripe and connected it to Ghost with the API keys/tokens. These tokens are the test ones. When i subscribe and add my test stripe card details, i can see the membership added to stripe under test data. However the user is not updated within Ghost?
Am i doing something daft here…?
Thanks,
Hi @rickdonato :wave:. When you say test tokens does that mean you have your Stripe account in test mode? And just to clarify when you say “user” do you mean member? Just asking so you aren’t getting users and members mixed up :slightly_smiling_face:
I managed to fix this in the end. The issue was due to running ghost with a selfsigned cert.
Stripe then reported TLS errors regarding the webhooks.
So you can’t use lets encrypt SSL?
This post is five years old. :) Lots of people use Lets encrypt in 2024 with no problems.
It’s way to easy to look at the related posts section and accidently reply to something really old. Gotta look before you post! Or at least, I do!
