Using Ghost 4.24.0, the other day I was switching between official themes (Chrome 96.0.4664.55) in order to try and isolate why I couldn’t do so with Firefox 94.0.2 (as I too experienced this Ghost bug, with Firefox but not with Chrome).
At various points I was going from Edition → Edition → Edition, trying to capture some network request data. As I couldn’t get the data (don’t ask me why) I then tried going from Edition → Dawn and back to Edition again. Although I’m a bit fuzzy on the exact point that data was lost, I think it was when switching from Edition → Dawn → Edition that a bunch of the site’s data got erased.
Specifically,
Lost:
Code injection
Site design images
Brand colour
Time zone
Site social media accounts
Site description
I’d removed some pages from the navigation menus, which reappeared
I’d erased some default pages, which reappeared (or was it just the navigation menu stuff that reappeared? I forget, sorry)
Ah yeah, forgot to also mention: I’d previously enabled the tiers lab, but when all the above got erased the tiers option got turned off, even though it’s advertised as a one-way street. Nonetheless, upon re-enabling tiers I noticed that the data I’d inputted into the two tiers I’d created hadn’t gotten erased.
Hey @Stromfeldt Thank you for the report. Did you have any modifications in the Edition/Dawn, for example different ghost-api specified in theme’s engines configuration? Would be awesome to get a very specific and easy to follow reproduction case for this.
Nah, I’d done nothing on those levels to the themes or instance, only what I’d mentioned. The only thing I can add, and it’s probably nothing, is that when I went to update the instance from 4.24.0 to 4.25.0 this morning I was given the following message, which I’ve never seen before. (Unfortunately I ran the suggested command and so don’t know what the permissions were.)
Hey @Stromfeldt. It seems like this has been the only report of this type of bug in a long time, although it’s quite concerning one as it has to do with data. Is it possible that you’ve had multiple sessions/windows going at the same time or some other “user triggered” override of the settings?
Yes, I had admin sessions open in two browsers at the same time (Firefox and Chrome), both logged in with the same staff member. As mentioned, I was (as instructed by someone else) executing a “copy as fetch” request so we could try and get to the bottom of that aforementioned theme change validation bug. After getting the “copy as fetch” data in Firefox I left the Firefox admin window open as I figured I’d be coming back to it as soon as I got the fetch data from Chrome. As I couldn’t get the “copy as fetch” request to work in Chrome, it was in Chrome that I repeatedly switched back and forth between the official themes while the admin session was still open in Firefox.
