Not sure where to go from here, would be nice to use my selfhosted picture host for inserting pictures. The only way I can insert pictures is clicking to select an image in the post.
Hi @mattgphoto With custom embeds, you can only use provider URLs that support oEmbed format. Ghost uses this package internally to do oEmbed parsing - oembed-parser - npm, and the list of supported providers can be found in this section - oembed-parser - npm
Unfortunately, it’s not possible to set an image URL from the UI in current versions of Ghost as explained here:
