This theme is invalid and cannot be activated. Fix the following errors and re-upload the theme. Fatal Errors Must-fix to activate theme
  • What’s your URL? This is the easiest way for others to help you==>> https://paintmia.com
  • What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic==>> i hope the last version is 5.35.0, I checked in the Ocean
And
  • How was Ghost installed and configured?==>> it was made by a team
  • What Node version, database, OS & browser are you using? ==>>I use Chrome
    ==>> "Oops! You seemed to have used invalid Handlebars syntax. This mostly happens, when you use a helper that is not supported.
    See the full list of available helpers here.
Affected files:
  • default.hbs: Missing helper: “match”"
Check if you have an unclosed tag or extra closing tag somewhere around that {{#match}}{{/match}}.
an orphaned {{#if ...}} with no closing, or a {{/if}} with no opening (or other handlebars helper that needs to be opened/closed like #get).
I’ve had similar errors caused by that.
hello!
this is my problem, where can I look to change this?I am very very new to this process
I can’t help you better than the docs can with getting up to speed, unfortunately.
I thank you from the bottom of my heart, you realize that I have read everything possible, the point is that I understood that it is a wrong command or it is not closed, my problem is that I do not know programming, I have extensive knowledge about programming and the site. I looked for where to modify this error but I can’t figure out if I should go to Code injection? to make these changes?
Do you think it’s better to look for a specialist to fix it, than to break it? :)))D
hello again !
in the meantime I understood that I had to install an editor, I did it and downloaded the original theme because that’s where I understood that there was a problem and I’m trying to check it. But I can’t find the word that the “match” error refers to anywhere. Is what I have done so far good?
Following your advice, I fixed the problem with “match” and another Missing helper appeared: “if_eq”. I just found out how to modify them and finished them. Thank you very much.
