Timezone bug when using logging__useLocalTime and TZ
Hi Ghost team, I’ve noticed strange behavior with timezones in the latest Ghost version (6.x).
If you set the environment variables in Docker simultaneously:
- logging__useLocalTime=true
- TZ=Europe/Kiev
Then:
  • Log files show the correct local time (Kyiv, UTC+3)
  • Console output shows time three hours ahead of Kyiv
If you remove logging__useLocalTime and keep only TZ=Europe/Kiev, then:
  • Console shows the correct Kyiv time
  • Log files save time in UTC
If you remove both (logging__useLocalTime and TZ), then both console and log files show UTC time.
It would be great to fix this bug so that log and console times match when using the local timezone.
Thanks!
