It’s been a while since I maintained this site, but I noticed it’s throwing an error about the current casper theme being unavailable, so I figured I’d try to run ghost update and see if that fixes it. However, I’m getting this error:
So the Ghost-CLI has added a migration to add a new folder in the content folder. This code doesn’t protect against the folder being created already. Have you manually created content/settings? If not, can you remember the steps you did?
I would suggest to remove the content/settings folder if you haven’t used this folder yet.
Checking system Node.js version Checking logged in user Ensuring user is not logged in as ghost user Checking if logged in user is directory owner Checking current folder permissions
System checks failed with message: ‘Linux version is not Ubuntu 16’
For local installs we recommend using ghost install local instead.
? Continue anyway? Yes Checking operating system compatibility [skipped] Checking for a MySQL installation
Running sudo command: systemctl is-active ghost_musingmommy-com Validating config [skipped] Checking folder permissions Checking file permissions Checking content folder ownership Checking memory availability
That returns the version of a another blog I’m running on that machine, but not the version of the blog whose directory I’m in. Sounds like I have a weird setup and should expect troubles, I will troubleshoot more later, thanks for helping!
