Hoping someone can help, since upgrading to 3.22.1 all of my members and publication info disappeared.
I have managed to populate this all again, but am unable to select any Subscription pricing. This area just shows an empty box under Plan currency and nothing help.
Upgraded to 3.22.2 this morning and having same issues.
Okay, no worries, if you are able to look in the directory you have Ghost installed in, you should see a folder called content and inside there another folder called data.
That data folder contains a lot of json files which are backups or your database before each upgrade.
If you would be able to open the most recent of those files and search for members_subscription_settings you should see something like:
If you would be able to copy that, and remove the bits which have the secret_token, and paste that here, we will be able to work out what’s causing this issue and make a fix for it
Ok, I will try and do this - any good guides out there to help?
I have tried ghost update 3.21.1 --force
and get the following error Checking for latest Ghost version
A CliError occurred.
Message: The custom version specified: 3.21.1, is less than the current active version: 3.22.2
OS: Ubuntu, v18.04.4 LTS
Node Version: v10.21.0
Ghost Version: 3.22.2
Ghost-CLI Version: 1.14.1
Environment: production
Command: 'ghost update 3.21.1 --force'
I rolled back to a snapshot on Digital Ocean because I couldn’t fix this.
Made the mistake of upgrading to 3.23.1 this morning and I am now unable to change any settings with the following error: Permission error, cannot edit setting. Attempted to access core setting from external request
