pirmax
June 22, 2020, 10:31am
1
Hello,
Since a few updates, I no longer have access to the member functionality, finally, it no longer works correctly.
The price remains at zero euros.
I have already reinstalled several themes and I have also deactivated / reactivated the functionality in the admin.
Thank you.
If you’re looking for some help, it’s important to provide as much context as possible so that people are able to assist you:
What’s your URL?
What configuration?
What browser?
Thanks!
pirmax
June 22, 2020, 5:40pm
3
Hey,
Thanks for response.
I use last Ghost version.
The blog URL is https://www.yubigeek.com (https://www.yubigeek.com/subscribe/ )
The issue is on every browser and I haven’t error in JS console.
No currency symbol and no prices.
I tested the Lyra theme too, and the issue is always here…
Thanks.
You need to provide the actual version number of Ghost you’re using rather than the “last version”. Have you made sure that all your members / Stripe settings are filled in correctly and that you’re no longer using test details?
pirmax
June 28, 2020, 10:29am
5
I use 3.21.0 version.
The Stripe settings are saved, and I’ve enabled members…
pirmax
June 29, 2020, 9:53am
6
I’ve the next error in Google Chrome console… Maybe this will help us?
Thanks.
Those errors make me think that the Stripe keys you’ve entered aren’t correct. Try entering them again and making sure to click save
pirmax
June 29, 2020, 5:57pm
8
It was already new Stripe API key pairs, I just generated new ones, and I’m still having the same problem!
