Usage of "translate"
Hi there!
Being a really newbie I’m dealing with the translate command.
At Ghost Handlebars Theme Helpers: translate it says I should create a folder “locales” - so where can I do this using the online Ghost platform (not self-hosted)?
Thanks
Udo
The locales folder is included in the root of the theme. That means you’ll need to edit your theme and add the folder to add translation support.
Thanks a lot!
Would have to upgrade my plan, so let me think about it :slight_smile:
