I’ve seen the use of the Tags box in Post Settings to assign different header sizes for the post:
Can someone explain how this is being used to alter the CSS, or point to documentation on using tags in this way?
Many thanks!
Josh
Many thanks!
Josh
There are a few concepts that come together to achieve something like that.
In a Ghost theme, every post is displayed using the “post context”. This context holds all the information that is stored on a post (or technically, the one that is publicly available).
Within this post context, you can then use the #has
-helper to ask Ghost whether a certain Tag is applied.
If that is the case, you can then apply a CSS class to the title.
Something like this:
{{#post}}
<h1 class="title {{#has tag="#title-large"}}title-large{{/has}}">
This is a large title, if the #title-large tag is applied
</h1>
{{/post}}
Using helpers you can build some pretty complex conditional designs.
Edit: just remembered that the Casper theme also has a pretty interesting conditional CSS class for typography, using the #match
helper:
Many themes include the tags as classes on an outer element. If that’s the case, you might not even need to edit your theme, but could just add a style that applies to h1s if your post has that tag.
<style>
.tag-hash-big-title h1 { font-size: 100px }
</style>
Thanks Jannis, this is really useful.
