Hi Ghost community,
I was wondering if it’s possible to use Postmark’s new Broadcasts feature to send Email Newsletters from Ghost instead of Mailgun?
Thanks! Looking forward to the replies ![]()
Hi Ghost community,
Mailgun is the only supported provider for sending newsletters directly from Ghost.
Ah, I see. Thanks, @kevin for the quick reply!
I wanted the same! You can use my open sourced integration for Postmark, check it out here: GitHub - vicsn/ghostmark: Ghost integration which allows sending email via Postmark and let me know what you think.
