Where to find template files, etc for FB integration, Disqus etc
I’d like to get either Facebook comments and integration working or a Disqus integration going. Each guide gives me a code block and tells me to add it to a file (templates?) Where are these files located? I’m not self-hosting.
In the theme files.
It seems on the Ghost Pro starter plans you can’t edit the files though.
 Mark
You need to edit your theme files.
You need to look for the post.hbs file . The main file for the single post where you can add Facebook comments or Disqus integration.
I did eventually figure out how to download and edit my theme but didnt get the desired results. I’ll keep tinkering and come back with more detailed questions.
thanks!
