Where to put html documents to embed with iframe
Hello I am running ghost 2.3.1 I am wondering how I can host some html documents that I want to be embedded with an iframe, is it possible to create a directory within my ghost installation to place these documents ?
Hey there! Uploading files such as HTML files can be done in several ways. I found a post by @vikaspotluri123 who explains the options you have very well:
You can then use the custom HTML card and add an iframe:
<iframe src="https://your.blog/assets/file.html"></iframe>
Hope this helps!
