Newbie here. Installed Ghost using CLI on an AWS EC2 instance, trying to start it for the first time. But ghost start simply times out and gives the following “Could not communicate with Ghost” error. Not using Elastic IP or anything. MySQL is on a remote host.
- GhostCLI 1.25.3, Ghost 5.71.1
When I runghost start:
ghostbloguser@ip-172-31-0-81:/var/www/blog.knravish.me$ ghost start -V
https://careers.ghost.org
+ sudo systemctl is-active ghost_blog-knravish-me
Using https on all URLs is highly recommended. In production, SSL is required when using Stripe.
Support for non-https admin URLs in production mode is deprecated and will be removed in a future version.
[19:31:13] Checking system Node.js version [started]
[19:31:13] Checking system Node.js version - found v18.18.2 [title changed]
[19:31:13] Checking system Node.js version - found v18.18.2 [completed]
[19:31:13] Ensuring user is not logged in as ghost user [started]
[19:31:13] Ensuring user is not logged in as ghost user [completed]
[19:31:13] Checking if logged in user is directory owner [started]
[19:31:13] Checking if logged in user is directory owner [completed]
[19:31:13] Checking current folder permissions [started]
[19:31:13] Checking current folder permissions [completed]
[19:31:13] Validating config [started]
[19:31:13] Validating config [completed]
[19:31:13] Checking folder permissions [started]
[19:31:14] Checking folder permissions [completed]
[19:31:14] Checking file permissions [started]
[19:31:14] Checking file permissions [completed]
[19:31:14] Checking content folder ownership [started]
[19:31:14] Checking content folder ownership [completed]
[19:31:14] Checking memory availability [started]
[19:31:14] Checking memory availability [completed]
[19:31:14] Checking binary dependencies [started]
[19:31:14] Checking binary dependencies [completed]
[19:31:14] Checking systemd unit file [started]
[19:31:14] Checking systemd unit file [completed]
[19:31:14] Checking systemd node version [started]
[19:31:14] Checking systemd node version - found v18.18.2 [title changed]
[19:31:14] Checking systemd node version - found v18.18.2 [completed]
+ sudo systemctl start ghost_blog-knravish-me
+ sudo systemctl stop ghost_blog-knravish-me
✖ Starting Ghost: blog-knravish-me
A GhostError occurred.
Message: Could not communicate with Ghost
Suggestion: journalctl -u ghost_blog-knravish-me -n 50
Stack: Error: Could not communicate with Ghost
at Server.<anonymous> (/home/ghostbloguser/.nvm/versions/node/v18.18.2/lib/node_modules/ghost-cli/lib/utils/port-polling.js:91:11)
at Object.onceWrapper (node:events:631:28)
at Server.emit (node:events:517:28)
at emitCloseNT (node:net:2221:8)
at process.processTicksAndRejections (node:internal/process/task_queues:81:21)
OS: Ubuntu, v22.04.3 LTS
Node Version: v18.18.2
Ghost Version: 5.71.1
Ghost-CLI Version: 1.25.3
Environment: production
Command: 'ghost start -V'
Additional log info available in: /home/ghostbloguser/.ghost/logs/ghost-cli-debug-2023-11-04T19_36_14_403Z.log
cat /home/ghostbloguser/.ghost/logs/ghost-cli-debug-2023-11-04T19_36_14_403Z.log gives:
journalctl -u ghost_blog-knravish-me -n 50 gives:
Hint: You are currently not seeing messages from other users and the system.
Users in groups 'adm', 'systemd-journal' can see all messages.
Pass -q to turn off this notice.
-- No entries --
ghost doctor gives:
✔ Checking system Node.js version - found v18.18.2
✔ Checking logged in user
+ sudo systemctl reset-failed ghost_blog-knravish-me
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v18.18.2
I’ve gone through many similar posts on both this forum and GitHub Issues. Some had other issues, many have gone stale. Would really appreciate any help.
