Bug in images which are uploaded locally
I am having issues uploading the images from my laptop. When I upload them, they appear like they should be. But when I go back, save the blog and come back to edit it, (not published yet) the images get broken. (see the attached screenshot)
When I upload any image by the url, it works fine. Even if I go back and then open the blog for editing.
What should I do?
Thanks
Sounds like a problem with retrieving the local images.
How are you hosting your blog? Are you using any storage adapters (asking because I have seen this behaviour with wrongly configured adapters)?
Two other reasons I’ve seen that cause similar problems:
  1. Your Ghost is configured with the url value as http but you’re hosting on https so you have mixed-content errors
  2. You have your Admin area hosted on a different domain to your front-end and you have hot-linking protection enabled somewhere in your hosting stack
