Hello all,
What are the exact differences between the local install and the production install/ Ubuntu?
I’m new to Ghost and I asked myself what the differences are. What I know is that on the production install you have to create a new user and setup Nginx & MySQL. But are there also differences in performance?
I’m planning to host Ghost on a server and MySQL on another one, since I already have a MySQL DB server. Now, I would like to know if Ghost would still work efficient if I install the local version on the web server and manually config the SQL service.
Thank you very much
I don’t know every difference, but Ghost’s local install option is clearly labeled as not being for production:
Some differences I see are:
- Production instance is managed by systemd for starting on boot and restarting
- MySQL for production vs SQLite locally
- Auto-restarting when changes are made locally-- useful for development but wasteful in production
- Improved performance with Nginx reverse proxy in production. No reverse proxy locally.
It should be no problem to use the production
install with MySQL on a remote host. That’s almost certainly what Ghost(Pro) is doing in production.
You should be able to use a production install and set your MySQL hostname to the remote host.
