Footnotes - again
I wrote a post about another option for footnotes, if anyone is interested:
It joins my previous post about footnotes (which unfortunately leaves them not so nicely formatted in email) :
and the markdown option, which unfortunately only numbers sequentially within the same card:
Thank you so much for this! It’s one of the biggest features that I miss the most from my previous provider, so it’s fantastic to finally have them back again. <3
Hi Cathy,
I pasted your code in the footer of the theme but looks like it doesnt work. Well, Im probably doing something wrong. I pasted the code, than in a post, at the side of a word I wrote “word[[1]]: this is the text of the note.”.
But when in the preview view I just see “word[[1]]: this is the text of the note” as I wrote and not the awesome not you show in your post.
I tried to put the text in another line as you said but it doesnt show up.
Edit: now I can see the number of the note on apex but I dont have anykind of pop-up that shows the text of the note.
Any help please?
Thank you!
I’m not sure which set of directions you’re following - is it the second link above? If so, you need a structure like:
Blah blah blah [[1]]
blah blah blah
[[1]]: This is the footnote text for note 1.
yes I’m using the second link. But I think I know whats the problem.
I’m using HTML cards because I need custom fonts and other style setting for part of the text. So I’m using your method which I suppse works only in a normal text card and not in an HTML one.
<section>
<p style="font-size:20px; font-family:Times LT Std Roman; text-align: justify;">
text text text[[1]]...
[[1]]: This is the text.
</p>
</section>
Sorry I didnt get it.
I will try in a normal post.
Thanks for sharing your method!
You may also need to tweak the css selectors (look for document.querySelectorAll) to match your theme’s structure.
