Can someone please explain this guide into normal English. Am I supposed to use this trick to be able to create a foot note for my post?
Yes? Did you try the example? Where are you stuck?
However unless you are emailing, I recommend this approach instead:
So I didn’t read this link, but if your intent is to create footnotes you could start with this blog post Cathy wrote about incorporating footnotes into Ghost posts. Maybe read that and give her implementation a try.
If you need more help after trying her suggestions circle back here for more guidance and see what the community can offer.
