Ghost/digital ocean
  • What’s your URL? Digitalmisfit.uk
  • What version of Ghost are you using? 2.0.3
  • What configuration? Digital ocean pre configured droplet
  • What browser chrome desktop/mobile
So I’ve installed ghost via digital ocean using the preconfigured droplet.
It’s installed to /var/www/ghost but I’m still seeing the default landing page.
If I got it via the server IP the install shows just fine.
I’ve noticed that there is a html directory inside of the www dir, could that be the issue?
Check the docs over at DO, there might be something there that can help:
I’m officially dumb. Thanks for that, it’s sorted now.
