I’m using the admin editor and added a Header. I added content and added a few lines with some breaks inbetween. When I save, everything gets rendered out ok, the breaks turn into HTML <br>s and it’s all good…
However, whenever I go back into the editor, the breaks are removed, and if I save again, they aren’t there any longer.
I had this problem a few months back and then I thought it got fixed. Can you confirm which ghost version you’re running?
I’m on Ghost Pro, so I imagine the latest.
Rats!
@Kevin described the ability to use line breaks as intended behavior here: Header card improvements - Ghost Changelog
