Ghost was installed in docker containers using ghost-docker image -
OS: Debian GNU/Linux, v10
Node Version: v12.19.1
Ghost Version: 3.38.2
Ghost-CLI Version: 1.15.2
Environment: production
browser - google -
System stack check skipped
Checking system compatibility [skipped]
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking free space
One or more errors occurred.
- Validating config
Error detected in the production configuration.
Message: Port ‘2368’ is in use.
Configuration Key(s): server.port
Current Value(s): 2368
Help: Run ghost config <key> <new value> for each key to fix the issue.
I am trying to change the url of the website being hosted in the container, by using ghost config command . Then I try to restart ghost, I get above error when I do ‘ghost restart’ command and when I check for ghost instance using command ghost status it says ‘No installed ghost instances found’
Can anyone please help me how to fix this? appreciate the help in advance.
