Translating strings in Portal and our member emails is now our most-voted for feature on the forum. Translating comments and search crop up regularly too.
We have had a few PRs that aim to add support to individual components of Ghost, but we believe that i18n needs to be solved with a single solution and therefore we have put together this plan for the requirements and how we believe it needs to work.
We’d love to work together with a group of contributors to deliver i18n as part of Hacktoberfest 2022.
Problem
At present, only themes are translatable using a custom-built i18n framework that we do not want to build on. Portal & emails are part of core, not themes. Comments & search are related to themes, but the text strings within are not. They each have one set of strings, which only need translating into each language once and so it makes sense to have these translations be part of Ghost core.
There is a secondary use-case, where users want to be able to customise copy, rather than translate it. For example, the default text shown in the empty search modal is “Search posts, tags and authors” but some sites use different terminology for tags. This use-case is different and may warrant an escape-valve system for custom strings in future, but our immediate focus is on solving core translations.
Solution
We want to be able to serve translated emails and widgets, based on the language set in general settings. Technically, the solution boils down to answering two key questions:
- Where do the translated strings come from?
- How do the replacement strings get interpolated?
The answer to 1 is “a JSON file” of some description. We do not want to manage translations in a 3rd party tool like transifex, but we’d like to keep all of the JSON files in GitHub. It needs to be possible to load the strings and pass them to all the places they’re needed.
The answer to 2 is a {{t}} helper that needs to exist in both react and email templates. We want to keep our existing pattern from theme i18n of using the default string as the key. This means that when a default string is changed, it needs to be re-translated in all languages, which is desirable as changes are usually more than cosmetic.
We will also need a way to collect all the default strings and compile them into a new JSON file ready to be translated.
For email templates, it makes sense for the interpolation to be dynamic, done at the time of email-sending as this is a server-side system. For our react “widgets”,we would like to create a custom build for each translation, so it becomes possible to load e.g. portal-es.min.js.
Several aspects of i18n will be made significantly easier by ensuring that all translatable components, and the translations themselves live together in the Ghost monorepo, which is WIP. Portal should be migrated this week, which will allow work to begin.
Technical Plan
Our basic requirements are:
- Load a single set of translations + (maybe) a set of custom strings into react widgets
- Load a single set of translations into Ghost core for emails
- Future: Load translations for Admin
- Interpolation tools for Handlebars and React
- Be able to use the default string as the key
- Be able to generate a new language file with all available keys
- Not have to load e.g. all of portal’s translations into comments
- Have a single place, in GitHub, where locales are defined
- Ideally: generate a build per locale for each JS widget, e.g.
portal-es.min.js
That last requirement is the hardest, as we will need to figure out a build step for our react projects… but this should be a one-off piece.
The i18next framework appears to support every single one of our requirements, including fallback-based keys, namespacing and having tools for extracting translation strings. It’s also extensible with plugins and has links to tooling for managing the translation process - so we could have a yarn check-translations command to view what’s not translated.
Expected structure:
- A new
ghost/localesfolder in the monorepo contains namespaced JSON files e.g.locales/es/common.json,/ocales/es/portal.json,locales/es/email.json - For Node.js/email-templates we do one of:
- (Preferred) The correct path is loaded from config based on environment
ghost/localesgets copied intoghost/coresomehow
- Then for react:
- Use code-splitting to generate individual versions of portal, comments and search for each supported locale.
I was able to find some details of using i18next with webpack to create a a build step using “code splitting” but it doesn’t quite achieve what we want. We are currently investigating switching to Vitejs for our build tool - and this may end up being an additional prerequisite.
Milestones
This project has prerequisites, is fairly complex and has lots of different phases in which different community members may wish to get involved. Therefore, I’ve broken the project down into milestones and will keep this thread up to date with where we are.
Milestone 1: Monorepo
- Portal needs to be merged into the monorepo
- Comments and search will follow later, but the project can continue without them.
Who: This milestone is currently being worked on by the Ghost team.
Milestone 2: Framework and build tools
- Implement the “expected structure” from above
- Get the basic pieces of i18next in place
- Figure out if we need to switch to vitejs in Portal (may need help from Ghost team)
- Have 1 interpolate string in each of email and Portal
- Tooling for extracting strings & generating files
Who: Looking for interested contributors, Ghost team will help and/or kick this off if needed.
Milestone 3: Interpolated Strings
- All strings in Portal and Member emails (signup, signin, subscribe) are interpolated using the
{{t}}helper and the default, existing US English string as the key. - comments-ui and SodoSearch should also be in the monorepo by now, and so these strings can also be interpolated.
Milestone 4: Translations
- Tooling for extracting strings into new locale files should be perfected
- Getting all strings translated for additional languages.
Next steps: Once Portal is available in the monorepo, I’ll raise a GitHub issue for milestone 2 and link it here.
If you’re interested in helping with milestones 2-4 of this project, I’d love to hear from you in the comments below ![]()
