Help me undestand how to create a "private/hidden" membership option
Hey guys. I’m starting a coaching business, which should have different plans, say:
Basic: $X/mo
Pro: $XX/mo
Premium: Inquire.
and so on, and even tho the content they will get from my Ghost (emails, articles, what now) would be the same for every member, the level of personalized coaching service won’t.
I’m concerned about the “Premium” option because ideally, I wouldn’t like to show how much more would it be, as I would probably calibrate it over time and depending on my availability, but even then I would still want to use Ghost’s recurring billing/system/invoicing and all.
Is there a way to create a “private/hidden” membership page that I can only send to the few people who qualify as Premium leads?
Thanks!
Under Settings → Membership → Customize Portal, you’ll find options to toggle on and off which tiers are shown in Portal. That way, you’d still be able to have your premium tier but not have it shown publicly.
Make sense. And how could I send someone to this hidden tier?
Is there also a way to add a selection to a tier? I Plan a plus membership which is dependend on the company size. I could create an extra tier for each, but I was wondering if there is an alternative solution?
I had the same query here:
Let me know if you find a viable solution!
Did this recently for The Stack: Membership
It’s not possible within portal, but if you’re running a theme with custom membership pages available, it’s not too bad.
Thanks. So the solution is to create on top of /#/portal a custom membership page, where you can also show the tiers (which you hide on /#portal) and also a custom tier, that leads to a form / mailto.
That’s the current solution, yes. :)
