can someone guide me on how to update the ghost droplet. It is showing me these errors
Last login: Wed Jun 2 16:01:50 2021 from 42.106.8.68
root@blog-website:~# sudo -i -u ghost-mgr
ghost-mgr@blog-website:~$ cd var/www/ghost
-bash: cd: var/www/ghost: No such file or directory
ghost-mgr@blog-website:~$ ghost update
Working directory is not a recognisable Ghost installation.
Run `ghost update` again within a folder where Ghost was installed with Ghost-CLI.
I think you’re missing the / at the beginning here, it should likely be /var/www/ghost.
I would suggest running CLI commands one at a time and examining the output of each to ensure it’s worked, if it hasn’t worked you’ll usually be told why. If you try running all the commands at once or don’t examine the output and continue anyway then any further commands are unlikely to work or could have unintended consequences.
