Hi, I am looking for a theme which includes a side navigation bar which organizes all posts into a folder structure. Something similar to the image linked below.
Each post would have 3 tags:
- Year created (2017, 2018 etc)
- Work type (professional, personal)
- Field (Code, Model, Photography)
Ideally, the posts would be organized into folders by a specific set of tags tag, For example, 2016,2017,2018 etc. And there would also be a way for the visitor to click “sort by Work type/Field”
This would re-generate the folder structure grouping the posts by those tags
Does anyone know if there is a similar solution to this?
Hey @Tokusei
Maybe there’s something in our Marketplace that can meet these requirements?
If not the Ghost community might be able to step in and come up with something more custom
hi, Thanks for the reply. I checked the marketplace but couldnt really find any template which matched, if you know of one, please let me know
You could look at Ghost themes designed for Documentation/Knowledge Base sites, which tend to have structured side menus. Here is one example with expanding menus:
I maintain a list of resources for finding Ghost Themes that I use for theme hunting:
https://ghost-o-matic.com/where-to-get-ghost-themes/
