Mastodon and Bluesky embeds not working correctly
Fill out the following bug report template with as much detail as possible!
Are you sure this is a bug? If you just need help, post in the developer help category. If it’s a feature request, head to the ideas category.
Issue Summary
Steps to Reproduce
  1. This is the first step…
  2. This is the second step, etc.
Setup information
Ghost Version
6.0
Node.js Version
If self-hosting - share which version of Node.js you’re using.
How did you install Ghost?
Provide some details about your install of Ghost if you are self-hosting.
Include further details about your hosting and OS.
Database type
MySQL 5.7 / MySQL 8 / SQLite 3 / Other
Browser & OS version
Include if reporting frontend bugs.
Relevant log / error output
Copy and paste any relevant log output. Use backticks to format this into code.
From looking at the source code, this does appear to be a Ghost embedding bug. The HTML/CSS for the post itself does not constrain its own size from what I can tell.
Thanks for the reply. Do you think it’s a theme issue, or a wider problem with embeds in Ghost?
I’m an amateur CSS/HTML sleuth, but from where I saw the width being set, it appeared to be done in the new Mastodon card. I haven’t upgraded to 6 to check myself.
Any response from Ghost devs on this? The broken embeds in the email are already attracting complaints from my early subscribers :frowning:
There’s not a dedicated mastodon or bluesky embed, so you’re using the generic embed, right? Because these embeds use javascript to retrieve content, but email clients don’t run javascript, they’re going to be missing content. (For the embeds that DO work, there’s custom code specifically to grab a preview image and send it in the email where the embed would be, linked back to the source site. (If you email a youtube embed and look closely at it, you’ll see that happening.)
What would need to happen for these other embed types is for there to be code that handles them in a similar way.
Meanwhile, a workaround is to create a screenshot of the content, paste it into the post, and then link the image back to the source. That works on both web and email.
Thanks for your reply. What I am doing is pasting in the link, eg from Mastodon or Bluesky. In the preview it automatically turns into the embed, and displays fine. On the website it displays too. I am not sure what is needed to get it working in the email, but I will note that with Buttondown (which I also use), there is no issue with email embeds. I am not a technical expert in email embeds, but if Buttondown can get it to work I am sure Ghost can too. It’s really not a great solution to use screenshots (for a start, accessibility, but also it’s just not technically elegant). I hope Ghost can fix this, as embeds in emails feels like it should be table stakes.
