The past two times I’ve upgraded Ghost (2.13.1 and 2.14.3) I’ve gotten the error below. Ghost is not running when I check, and simply running ‘ghost start’ after works as expected. Looks like the Ghost process is just not shutting down fast enough for the speedy upgrade process? Maybe a retry or two could be added?
Thanks,
Bryan
% ghost upgrade
_ Checking system Node.js version
_ Checking current folder permissions
_ Checking memory availability
_ Checking for available migrations
_ Checking for latest Ghost version
_ Downloading and updating Ghost to v2.14.3
_ Stopping Ghost
_ Linking latest Ghost and recording versions
_ Restarting Ghost_ Checking current folder permissions
_ Validating config
_ Restarting Ghost
_ Removing old Ghost versions
One or more errors occurred.
- Validating config
Error detected in the production configuration.
Message: Port ‘2368’ is in use.
Configuration Key(s): server.port
Current Value(s): 2368
Help: Run ghost config <key> <new value> for each key to fix the issue.
OS: freebsd, v11.2-RELEASE-p8
Node Version: v8.15.0
Ghost-CLI Version: 1.9.9
Environment: production
Command: ‘ghost upgrade’
