this blue line appears, which literally follows the mouse cursor, nothing is selected, I cannot write in any way, I have to exit and re-enter the article
The line should only appear when dragging a card and it shouldn’t get stuck If it happens again can you check the Console tab of your browser’s developer tools to see if there are any errors?
If you do get stuck like that pressing Escape should clear the broken drag/drop state.
