Problem moving to vps server
  • What’s your URL? This is the easiest way for others to help you
    blog.ofplayers.net
  • What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
Latest
And
    On the old server, through docker compose, mysql, and cloudflared running in the same docker network. On the vps, it’s still docker and mysql but it’s running on a linode vps and nginx proxy manager is used instead of cloudflared
I can’t really answer the last 2 so I’ll just put my issue here.
When I moved the mysql database and ghost content folders I assumed that you could just drag and drop them into a different server, use the same compose and it’d work, but the files were on a different path (/home/millions/site/ghost before vs /root/site/ghost after) and it seemed to not want to accept the database.
Since I have a backup of it, I started up a blank blog on the same domain (new server though) and got that up and running. I do want my old posts back though, and to access ghost again I’d have to go through the process of moving back to cloudflare tunnels, which I don’t want to do.
Is there a way to fix this or do I have to start from scratch?
Why not export from the old server, install ghost standard on new server, and import?
I already moved to a static site generator, but I did end up getting the ghost blog running so I could export it, I changed the env variable in the ghost container from my domain name to localhost, opened it in an incognito tab and I was able to get into the admin panel and export it
From there I think I could probably just do that but I’d already started using eleventy at that point so I just converted them to markdown and fixed the images
I recently shifted from shared hosting to a VPS server based in Kenya, but I’m facing some issues. My site loads intermittently, and sometimes I get server timeouts or DNS resolution errors. I’ve double-checked my A records and firewall settings nothing seems wrong.
Is there something specific I should be aware of when configuring (link removed) options for better regional performance or DNS propagation? Could it be related to name server latency or misconfigured Apache/Nginx settings?
Is this about Ghost?
