I’m trying to run ghost locally for development. I have followed everything up until and including “Start Ghost” in this tutorial: Ghost Docs
Everything ran perfectly without errors. But when I try to access http://localhost:4200/ it says Ghost Admin in the title and the spinner is visible in the centre. If I inspect the page I have the following errors:
Attempting URL transition to /
router.js:36 Preparing to transition from '' to 'home'
:4200/ghost/api/canary/admin/users/me/?include=roles:1 Failed to load resource: the server responded with a status of 404 (Not Found)
:4200/ghost/api/canary/admin/site/:1 Failed to load resource: the server responded with a status of 404 (Not Found)
router_js.js:108 Transition #0: home: transition was aborted
router_js.js:111 Attempting transition to error404
router.js:36 Preparing to transition from '' to 'error404'
router_js.js:108 Transition #1: error404: transition was aborted
rsvp.js:23 Uncaught Error: You must provide a param `path`.
at getParam (route-recognizer.js:174)
at Array.generate.<computed> (route-recognizer.js:267)
at RouteRecognizer.generate$1 [as generate] (route-recognizer.js:731)
at PrivateRouter.generate (router_js.js:2259)
at Class.generate (router.js:513)
at RouterService.urlFor (router.js:221)
at Class.error (application.js:126)
at Class._triggerEvent (router.js:1333)
at PrivateRouter.triggerEvent (router.js:193)
at Transition.trigger (router_js.js:490)
This is in the latest verison of Brave with the latest version of Ghost in the master branch (~2.28.0)
No errors in the console. Am I missing something?
