GhostAdmin is a Ember.js application, and i what precompile end run.
But is attached in ghostjs core.
In output i observed that ‘http://localhost:4200/’ has listen and when i try to access a get a error becount it try access ghostApi with some host that is responding localhost:4200 and not localhost:2368.
I read the code and not can found any instructions about this. But i imagine that is a tittle config.
http://localhost:4200 is the ember-cli process that watches for file changes and rebuilds the admin client for development purposes. You can also access http://localhost:4200/tests to run the client test suite.
I’m not sure I understand your question fully. What is it that you are trying to achieve as an end goal?
