What’s your URL? Local Installation
What version of Ghost are you using? Latest: 4.2.0
How was Ghost installed and configured? Followed documentation for local install
What Node version, database, OS & browser are you using? Current Node, default database, Mac OS, Chrome
What errors or information do you see in the console? n/a
I was following this: Ghost 4.0 - Really Terrible for Personal Blog - #10 by Kevin to remove membership features from the default Casper theme. When I remove the code from Default and Post pages it breaks the theme. It seems like the css is removed.
I undid the changes but the theme was still broken i.e. ctrl + z, saved and restarted Ghost.
Additional notes:
- Fresh install of ghost and Casper theme
- There’s no conflicting CSS or used injected scripts
Any suggestions on why the theme might be breaking?
Edit 1
Okay, I’ve half solved it myself. It seems to be only an issue when I save it with vscode. Would it be something to do with the encoding or end of line sequence?
