Ruby theme language switching
Hello. I want to make the sections I added in the screenshot below in the theme called Ruby in Turkish. How can I do it?
That’s Portal. It’s a separate React app, not part of the theme, and not currently easily translatable.
If you’re not on Ghost Pro hosting, you could fork it and manually translate it. Otherwise, you could find a theme that doesn’t use the portal-provided popovers and instead provides its own member pages. (I believe Dashi does this, and there are probably others.)
thank you. I want to use the fizzy theme but it doesn’t install properly. I opened a topic about it. can you help?
