Saving Settings/ Configs Error "Permission error, cannot edit setting. Attempted to access core setting from external request"
After upgrading to " Version 3.23.0", I can’t save any core settings at all with this error message:
  • What’s your URL? This is the easiest way for others to debug your issue
    https://medevel.com/
    Version 3.23.0
  • What configuration?
  • What browser?
    FireFox and Chromium
      2/ghost/api/v3/admin/settings/:1 Failed to load resource: the server responded with a status of 403 ()
      /ghost/#/staff:1 Autofocus processing was blocked because a document's URL has a fragment '#/staff'.
      vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:9100 Uncaught (in promise) Error: Request was rejected because user is not permitted to perform this operation.
          at e._createCorrectError (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:9100)
          at e.handleResponse (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:9098)
          at e.handleResponse (ghost.min-862d14919f4770fc05201dacad598ac9.js:1779)
          at e.n [as handleResponse] (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:2368)
          at e.<anonymous> (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:9087)
          at l (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:621)
          at Object.fireWith [as rejectWith] (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:622)
          at A (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:905)
          at XMLHttpRequest.<anonymous> (vendor.min-8588d6e951f88d5f76ef7dcf04aa957a.js:916)
    Updating any core settings, title, description, or AMP settings
Update:
What version did you upgrade from?
from 3.21.1
upgrade:
ghost upgrade
Creating new draft posts works, creating or updating posts works as well.
Hey @hamza_m :wave:
Could you provide some more information to help us reproduce the error?
Specifically -
  • What version did you upgrade from?
  • How did you upgrade?
Thanks!
I have the same error now.
Upgraded from 3.21.1 to 3.23 (due to issues with 3.22)
Same here from 3.14.0 to 3.23
from 3.21.1
upgrade:
ghost upgrade
I hope this will be fixed in the next update. Please notify us with the update.
Hi all! :wave:
We just released 3.24.0, which fixes this issue. Please update using Ghost-CLI :slightly_smiling_face:
I got DB connection error and it does not rollback to the previous version at all.
 ghost-mgr@ghost-s-1vcpu-1gb-ams3-01:/var/www/ghost$ ghost update
    + sudo systemctl is-active ghost_medevel-com
    ✔ Checking folder permissions
    ✔ Checking file permissions
    ✔ Checking for available migrations
    ✔ Downloading and updating Ghost to v3.24.0
    + sudo systemctl stop ghost_medevel-com
    ✔ Stopping Ghost
    ✔ Linking latest Ghost and recording versions
    + sudo systemctl start ghost_medevel-com
    ✖ Restarting Ghost
    A GhostError occurred.
    Message: connect ECONNREFUSED 127.0.0.1:3306
    Help: Unknown database error
    Suggestion: journalctl -u ghost_medevel-com -n 50
    OS: Ubuntu, v18.04.4 LTS
    Node Version: v10.21.0
    Ghost Version: 3.24.0
    Ghost-CLI Version: 1.14.1
    Environment: production
    Command: 'ghost update'
    Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2020-07-10T13_54_53_543Z.log
    You can always refer to https://ghost.org/docs/api/ghost-cli/ for troubleshooting.
    ? Unable to upgrade Ghost from v3.23.0 to v3.24.0. Would you like to revert back to v3.23.0? Yes
    + sudo systemctl reset-failed ghost_medevel-com
    ℹ Downloading and updating Ghost [skipped]
    + sudo /var/www/ghost/current/node_modules/.bin/knex-migrator-rollback --force --v 3.23.0 --mgpath /var/www/ghost/current
    ✖ Rolling back database migrations
    A ProcessError occurred.
    Message: The database migration in Ghost encountered an error.
    Help: https://ghost.org/faq/upgrade-to-ghost-2-0/#what-to-do-when-an-upgrade-fails
    Suggestion: ghost update --rollback
    Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2020-07-10T13_55_09_991Z.log
I have rebooted the server and restarted the MySQL and it works again.
The main error is resolved.
Thank you.
I’ve tried to update the injection code and get the same error here!
Ghost version:
Ghost-CLI version: 1.14.1
Ghost version: 3.29.1 (at /var/www/ghost)
Error:
ERROR "PUT /ghost/api/v3/admin/settings/" 403
MESSAGE: Attempted to access core setting from external request
level: normal
NoPermissionError: Attempted to access core setting from external request
