- What’s your URL? Won’t be relevant in this case
- What version of Ghost are you using? 5.17
And
- How was Ghost installed and configured?
I followed the official docs, using ubuntu nginx and mysql.
- What Node version, database, OS & browser are you using?
Node 16.17.1, Ubuntu 20.04 and Brave Browser - What errors or information do you see in the console?
No errors - What steps could someone else take to reproduce the issue you’re having?
It’s just a general question, not a troubleshoot.
Hi guys, hope you are doing great.
I accidentally deleted the “system” folder on one ghost instance. I checked the other ghost instance, and this folder is owned by Root and has only a folder called “nginx-root” inside and this folder is empty.
I don’t see any problems due to this folder missing, should I be worried with something?
Thank you
