Hi, I’m trying to customize a theme for a ghost site, and know by default ghost tends to use yarn for at least back-end/build-time js packages, then there’s typically an assets/js and assets/js/lib directory for manually added js files, and of course the gulpfile to direct what gets used as a site resource.
I want to install front-end js packages using a package manager tool - in the past I’ve used bower but they recommend migrating to yarn.
But the confusion comes in distinguishing using yarn for client-side js packages. The options I’ve considered are:
Use the gulp file to specify selected packages within node_modules/ to be part of the built assets.
Having two yarn.lock files. Seems like a bad idea and doesn’t seem to actually work, as yarn seems to look for the parent yarn.lock file even if you tried to set one up in the assets/ directory.
Keep using bower for client-side stuff. It’s technically still an option but don’t feel happy thinking about two different js package managers.
I ended up doing the following:
Installed whatever front-end things I want via yarn (e.g. yarn add jquery) which ends up as a ‘dependency’ in package.json . This’ll put things in node_modules with everything else, but we’ll deal with this in a second.
In the node_modules directory, notice how ‘dependency’ installed modules have a ‘dist’ directory compared to the ‘devDependency’ modules.
Installed as a ‘devDependency’ gulp-npm-dist - i.e.
yarn add gulp-npm-dist --devwhich provides some functionality to make getting the client-side js files from node_modules. You may also want to doyarn add gulp-rename --devwhile you’re at it. -
In your theme’s gulpfile, reference the packages
// gulp distribute node_modules files
const gulp = require('gulp');
const npmDist = require('gulp-npm-dist');
const rename = require('gulp-rename');
and add in a function to copy in the files.
// Copy node client-side
// dependencies to ./assets/js/node_dist
function copyNodeDependencies() {
gulp.src(npmDist(), {base:'./node_modules/'})
.pipe(rename(function(path) {
path.dirname = path.dirname.replace(/\/dist/, '').replace(/\\dist/, '');
.pipe(gulp.dest('./assets/js/node_dist'));
and reference it in your js gulp function to run and also to source them:
function js(done) {
copyNodeDependencies();
pump([
src([
'assets/js/node_dist/**/*.js',
[....rest of your code...]
