Too many login attempts
Please note: I am really new at this and therefore my technical knowledge isn’t great. It is modest at best.
Details:
  • Web: merecivilian.com
  • Ghost v3.22.1
  • Installed on DigitalOcean using 1 click marketplace
  • Cloudflare also being used - bypassing merecivilian.com/ghost*
  • using mysql database
  • I have access to the console on DigitalOcean
The Problem
when logging in on Ghost Admin, I get error: “Too many login attempts”
Steps taken
  • I have done the obviously thing and not log in for some time. I wait 6 hours and than 12 hours and still the error doesn’t go away. Rest assured, the password I am using is correct. I have not reset the password.
  • I have the Ghost app installed on my Mac and that still works. I suppose it’s already logged in.
  • iA Writer is where I write and the app is able to publish on my website, so that also works
The issue is only using through the browser. I have tried on different computers and different browsers. I also tried on another app Ulysses which also uses the login method and that doesn’t work.
I kindly request your assistance.
I found a solution that worked for me.
I wrote about it here:
You can fix it in config files - config.development.json or defaults.json
Change the minWait & maxWait & freeRetries
"spam": {
    "user_login": {
        "minWait": 600000,
        "maxWait": 604800000,
        "freeRetries": 4
Thank you, @Olesia!! This config worked for me! (My local install password mysteriously stopped working this morning so I needed to set up local mail and also change this "login retry" setting…)
Note though: I had to delete the trailing comma (I’m on Ghost 5.52, Windlows WSL2 local install) or else Ghost wouldn’t start:
"spam": {
    "user_login": {
        "minWait": 600000,
        "freeRetries": 4
    } , <--------------- Needed to kill this trailing comma
to fix this error:
