Unsubscribe...any tips?
Hi there,
Is anyone doing anything interesting when members unsubscribe from their newsletters on Ghost Pro?
I’d like to direct unsubscribers to a feedback form or something, but currently I cannot see a way to do that.
Does anyone have any cool ideas to capture someone unsubscribing and ping them a mail or direct them to a page?
Thanks…
Matt
The way I set it up for my clients is to use the Member Updated module in Make.
When a member is updated I check (using a filter) if they have unsubscribed from a Newsletter, in that case I trigger an e-mail using Sendgrid or the standard SMTP ‘Send email’ and fire off a Sorry to see you go.
THis seems like a great solution - thanks, will give that a test!
One question - you say ‘I check (using a filter)’ - is this a manual step or can you do this procedurally through Make?
