Hello, I am running 2.7.1 and am confused as to where the images are stored. Documentation says that the images would be under /var/www/ghost/content/images (or assets). Both those folders are empty, but a clean install of Ghost with Casper theme has several “Getting Started” posts, each of which have images. Am using MySQL as backend. Are they stored there as BLOBS?
Thanks,
-Tim
The casper images are hosted by Ghost, so they don’t get in your way! If you look at the image URL, you’ll see it says static.ghost.org/... rather than your domain.
Images are stored in the directory you specified (assuming a standard installation), and you can verify this by uploading an image via (e.g.) the editor and then checking again
Thanks! Uploaded and see the image in content/images.
