On upgraded ghost 3 → 4 → 5.
Members can subscribe. On login attempt:
- Login
- mail with link is sent for login
- After opening the link the subscribe button is shown
Expected behaviour is to show the logged user.
This is working fine on a fresh installation of Ghost 5.
Is there some config or difference in the tables?
Is there easier way to check and fix it instead of import + export.
Still not working.
What I’ve notice is that:
/members/api/member/
gets HTTP code 204 in the network tab.
While on the other blog which is working is 200.
Is there any ideas how to continue the investigation about possible reason.
I think the problem is related to CloudFlare settings:
When I stop the settings (activated for: site/*)
The login is working fine.
Need to find what settings is causing the problem.
The problem seems to be related to:
cache_level - everything
changing cache_level to standard fix the issue.
