DigitalOcean one click droplet
This issue is quite odd, I managed to have both transactional emails and newsletter emails working through Mailgun. Only making cosmetic changes to the site through the Ghost web browser UI I now am in a sitruation where transactional emails send fine (new subscribers and invite of colleagues works fine) but the newsletter shows this error:
It does not show me what is causing the error. When looking in mailgun its not showing emails are sending (it does show it attempted and succeeded in sending the transactional emails but does not register the newsletter)
I suspect Ghost is not communicating on the newsletter front with Mailgun but I am not sure how to troubleshoot.
Note the logs it shows in the image are the transactional emails I have tested lately, nothing from the newsletter test I showed the error messages of above.
I managed to run, the ghost doctor here is the output:
Working directory is not a recognisable Ghost installation.
Run `ghost doctor` again within a folder where Ghost was installed with Ghost-CLI.
ghost-mgr@Peri1:~$ cd /var/www/ghost/
ghost-mgr@Peri1:/var/www/ghost$ ghost doctor
https://careers.ghost.org
✔ Checking system Node.js version - found v18.20.4
✔ Checking logged in user
+ sudo systemctl is-active ghost_tetractysresearch-com
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v18.20.4
And ghost update yields the following:
✔ Checking for available migrations
All up to date!
Apologies if I feel like helping some neanderthal using Ghost (I pretty much am!)
Thanks again!
Without an error log, it’s hard to guess. Try to find the error log under your Ghost project’s “logs” directory, you may see many error logs there. The log without number suffix is the most recent.
Send a newsletter, and check the latest error.
If you have trouble finding related errors, please DM me with the error log file.
If you’re running in a VPS or otherwise have shell access, you’d look for it in the Ghost root directory, named config.production.json.
If you’re using Docker (includes Pikapods), you don’t necessarily have a config.production.json, but you have a Docker compose file that includes the same settings.
I had a similar issue recently. My account was put under a sending-limit from mailgun of 10 emails. I adjusted the batch-size for the sending in the config to 9 and it worked again until Mailgun lifted the restriction.
