Hello everyone,
This is issue number #12 of Ghost Tips & Tricks. Brought to you by Aspire Themes. Premium and high-quality Ghost themes.
Always make sure to backup your droplet before doing any server work.
If you already installed Ghost on DigitalOcean using the Ghost 1-Click App and want to install an additional Ghost instance on the same droplet, this step by step guide is for you.
I assume:
You are logged in to your droplet using SSH from the command line
Your domain name is ready and connected to the droplet IP
➊ You need the current MySQL host, username, and password.
cd /var/www/ghost/
cat config.production.json
Take notes of them. You will use them later in steps 3 and 5.
➋ Create a website directory, for example, ubud
cd /var/www/
sudo mkdir ubud
sudo chown ghost-mgr:ghost-mgr ubud/
➌ Login to MySQL and create a new database
sudo mysql -u root -p
CREATE DATABASE ubud;
GRANT ALL PRIVILEGES ON ubud.* to 'ghost'@'localhost' IDENTIFIED BY '7d150600c49e7c5860be7ce03d4f8df67259176738d926ec';
FLUSH PRIVILEGES;
exit
ghost
→ database user -
localhost
→ database host -
→ database password
➍ Switch to the ghost-mgr
user
sudo -i -u ghost-mgr
➎ Install Ghost and follow the installation steps
cd /var/www/ubud/
ghost install
That’s all that I wanted to share today, and I hope you find this post helpful.
Checkout previous parts of the Ghost Tips & Tricks series:
- Ghost Tips & Tricks #1 / Show Publish Date in the day time with AM and PM format
- Ghost Tips & Tricks #2 / Ghost Admin Right to Left (RTL) Support
- Ghost Tips & Tricks #3 / Deploy Your Ghost Theme Using Github Actions
- Ghost Tips & Tricks #4 / Create a Tags List Page
- Ghost Tips & Tricks #5 / Create an Authors List Page
- Ghost Tips & Tricks #6 / Change Casper Theme Fonts Using Google Fonts
- Ghost Tips & Tricks #7 / Tools I Use to Develop, Edit and Deploy Ghost Themes
- Ghost Tips & Tricks #8 / Membership Troubleshooting Tips
- Ghost Tips & Tricks #9 / Ghost Tags - Practical Examples to Use in Your Theme
- Ghost Tips & Tricks #10 / Anatomy of a Ghost Theme — Part 1
- Ghost Tips & Tricks #11 / Download and Upload Images on DigitalOcean
Also, check out my Ghost Websites Inspiration and Ghost Newsletter series.
Stay safe!
Ahmad
