Hello everyone,
This is issue number #11 of Ghost Tips & Tricks. Brought to you by Aspire Themes. Premium and high-quality Ghost themes.
Using the command line, you can download and upload your Ghost CMS images folder. I assume you can already access your DigitalOcean Ghost droplet from the command line locally from your computer.
I will use the SCP command-line tool. SCP term is shorthand of secure copy. It allows to securely transfer files between a remote server and a local machine. In our case, it will copy the images from the Ghost server to the local computer and vise versa.
Zip Images Folder
The first step for downloading the images is to log in to your DigitalOcean Ghost server and zip the images folder.
Login to your DigitalOcean remote server with your droplet IP address.
Replace 207.154.195.220 with your IP.
ssh root@207.154.195.220
Go to the Ghost installation content path.
cd /var/www/ghost/content/
Zip the images folder using the zip command.
zip -r images.zip images
You may need to install the zip command tool first if it is not available on your server.
The command line will check whether the zip tool is available or not and then give you instructions to install it if it is not available.
Now, you have the images.zip file ready for download.
Working with SCP
The SCP command needs two parameters, the first is the remote location file path, and the second is the local path.
scp REMOTE_PATH LOCAL_PATH
In our case, the remote path will be something like:
root@207.154.195.220:/var/www/ghost/content/images.zip
And the local bath, for example, will be on my desktop.
/Users/ahmadajmi/Desktop
Download Images
Combining the previous parameters, you can use the following command to download the images zipped file.
scp root@207.154.195.220:/var/www/ghost/content/images.zip /Users/ahmadajmi/Desktop
Upload Images
The other scenario is to upload the images from your local machine to the remote server; you can use the same concept. Flip the parameters to make the local path comes first and then the remote path last.
So, I assume the images.zip is on the desktop; the upload command will be.
scp /Users/ahmadajmi/Desktop/images.zip root@159.65.227.236:/var/www/ghost/content/
Unzip Images
After uploading the images.zip to the remote server, you can use the unzip command to unzip it.
unzip -o images.zip
That’s all that I wanted to share today, and I hope you find this post helpful.
Checkout previous parts of the Ghost Tips & Tricks series:
- Ghost Tips & Tricks #1 / Show Publish Date in the day time with AM and PM format
- Ghost Tips & Tricks #2 / Ghost Admin Right to Left (RTL) Support
- Ghost Tips & Tricks #3 / Deploy Your Ghost Theme Using Github Actions
- Ghost Tips & Tricks #4 / Create a Tags List Page
- Ghost Tips & Tricks #5 / Create an Authors List Page
- Ghost Tips & Tricks #6 / Change Casper Theme Fonts Using Google Fonts
- Ghost Tips & Tricks #7 / Tools I Use to Develop, Edit and Deploy Ghost Themes
- Ghost Tips & Tricks #8 / Membership Troubleshooting Tips
- Ghost Tips & Tricks #9 / Ghost Tags - Practical Examples to Use in Your Theme
- Ghost Tips & Tricks #10 / Anatomy of a Ghost Theme — Part 1
Also, check out my Ghost Websites Inspiration and Ghost Newsletter series.
Stay safe!
Ahmad
